I need to move my int ring
Otto J
Has anyone ever removed the interruptor ring on a bhj balancer,I need to remove it and or spin it to a different setting.
Otto,
I think Bill Anderson has had some dealing with BHJ balancers having the int ring positioned incorrectly. I think it was in a somewhat recent thread that he made his comments. Good luck with it. BTW how many degrees do you need to move it??? could an offset key solve the problem or would doing that alter the balance :confused:
I need to move it a few degrees,But an offset key couldnt do it
Otto,
you have a FAST right? I think you can offset the crank angle easier unless I am missing something
Mike
BHJ will press on a new one for you, but you have to tell them in detail exactly where it needs to go.
What are you cooking up here?
TurboTR
At one point was thinking I'd need more timing retard with a bigger shot of hose (lol) so was going to move the ring on mine ~ 5 deg or so closer to TDC. I don't see why you couldn't get a new ring from BHJ and just have a local place press it on for you?
TurboTR
Moving Interrupter Ring
Otto,
I can Help You With That Issue !!!!!
Dan Strezo
DLS Engine Development
219-956-3653
KLHAMMETT said:
Well im not at liberty
FWIW, too far off, and the engine will take a prelonged crank, or second cranking when cold.
There is a sweet spot for light load conditons.
Anything more, and I'd have to have send the Black Helicopters after you. :)
At least from what I've seen.
Distrubutor setup with the stock crank trigger?? Let me know how that works out, I have heard of many that have not had luck going that route.
It seems to work fine IME- At least it has so far on Art's tt v6 race car...
TurboTR
I guess that depends on who is helping you ;)
V6gofast said:
Otto,
Dan Strezo
219-956-3653
Dan thanks for posting,Came back today.
Thanks for taking care of that for me
