turbotaone
- Jan 22, 2003
Well I got both the heads off last night finally. I found that no.3
cylinder was the one that blew,it split the fire ring wide open
right above the header.I lucked out that it wasn't near a water
jacket or on the intake side. I'm confused with what I found
when I unbolted the heads Instead of head bolts
there were studs, All sixteen of them. Several of them had ARP
stamped on the end,except the four longest ones which had
nothing on them,and there were four of the short ones on the
exhaust side of the heads that had been ground down a little
bit(I assume for clearance). The nuts were not all the same either,
the nuts under the valve covers were regular five sided nuts and
the ones under the headers were like a twelve point star nut.
Should I leave the studs in the block and re-use them and the
nuts and just assume that they are all ARP? Or should I take out
the studs and replace them with ARP bolts? Is it normal to use
studs on the heads in place of the bolts?
James
James
