Thanks in advance
-Andrew
SignUp Now!In your signature you list a "HO coilpack", what is that? Do you have a scanmaster? If so list the readings in open and closed loop for comparison. This will give the guys on here something to work with.
What brand MAF lots of problems with after market ones.
Shot in the dark but I had one of the metal prongs on my module bent just enough that my car drove like what your describing. I was getting in a hurry and did not plug it in strait I guess.![]()
Check grounds? Swap the chip? I had a bad IAT sensor kill me for months til i noticed on Directscan that the temp never changed.
The coolant temp sensor for the PCM is the two pin or two wire sensor. But the ignition module would have been my first guess. And the Mass air will also give you a run. If its a aftermarket unit it my not fix anything. Is it? And have you checked for a voltage drop at the pcm for a loss of ground? The cam sensor will also cause some issues, I will still make sure its set correctly. I have seen it set just off a little and make some funny issues. And remove and reinstall the prom. I hope to help get you down the right track.
I finally got a crappy reading on the coolant temp sensor (the single prong sensor on the passenger side of the intake manifold)
Doesn't the single prong coolant temp sensor tell the ECM what temp the block is at?
