IAC adjustments
Pwt
I replaced my iac valve and adjusted my tps sensor per the iac procedure. I adjusted my idle stop screw to as close to 500 RPM +/-50 RPM as I could. My idle seems a little low which is causing my motor to shake when idling. Also when I put it in gear right away it jerks the car,but if I wait a couple of seconds before selecting a gear it's smooth. Any suggestions?
Make sure the IAC is plugged back up.
If it is, open the throttle blade a little bit until that issue goes away.
Oh, and get ready for all the ''you need a scan tool if you want to own one of these cars'' replies.
