tt455
- Apr 15, 2022
Here are my readings, what is my next step? I've read a bunch of threads and the link to IAC reset procedure, but when you get to step 6 it does not tell you if the car should be still running or just in the on position? From what I've read I think the car should be off but in the on position and then turn screw in small amounts, wait then should the next step be to start or just read the scan master?
It would be nice if there was a video on this since it comes up so often. To many it's simple but I myself being a 60's early 70's guy it's not. Not that I can't learn but I screwed this up like many before, by thinking I can adjust the idle screw. So trying to find the idle this way I lost my original setting, and now I have hard starting and erratic idle. The car is an 87 turbo t.
