IAC count on winaldl
5ltretr
I'm seeing 175 on IAC using winaldl,
is this even possible or is the conversion off with the program?
thanks
I'm using WinALDL and haven't noticed a problem with the numbers being off. I also have an OTC so that I could compare the two numbers. Sorry that I couldn't help. There are some settings that you can change within the program like for TPS at 0 percent but I don't remember seeing one for IAC.
Do you have another scan program to compare?
There is a right and wrong way? I didn't notice that when I replaced mine for the first time about 5 months ago. Sure hope I didn't do the same thing. How did you know or find out?
my rpm's where 600 at idle, IAC 175 at any speed (those are the clues).
I purchased the IAC angle boss from Johns performance,
they figured it out for me, I guess others did the same thing...
myles
