The IAC on my car seems to be operating inproperly. Once it warms up the idle jumps to 1700-1900rpm. I try to adjust the idle speed vs coolant temp but no effect.
I unbolt the IAC from throttle body and adjust idle vs coolant temp to both extremes but iac position does not change. Also I cycle the key but iac does not move. Sometimes it will shake a little but nothing.
I tried my IAC and fast on another vehicle and it works fine. Also ohm checked the wires and it checked out good.
TPS is set to 13. The target rate would not change from 10 while adjusting idle screw until the vehicle died, then it jumped to 71.
What am I missing or not checking? Vaccum leak maybe?
