iac setting procedure for DFI 6.32
whtturbot
Im currently running the calmap 6.32, and my question is. Do you use the factory reset procedure for the iac ?, and what is the best rpm to acheive while doing it. Also what should the TPS be set at?
TIA
Jeff C
87 T
It's been a while since I messed with DFI, but I'll try. Go to the Throttle Follower screen and get the IAC where it is barely open with the car warmed up and idling in park. Then reset the TPS to where it is just barely reading 0% (almost 0.5%). Your desired rpm is going to vary based upon your engine buildup
