Ever since I replaced the stock injectors with 60's, I havce a had a "hard start/stalling" issue. To start it I have always had to give it gas or else it would not start. Also at stoplights the car would stall half the time. I would have to put it in neutral until the light turned green. So while in BG I bought a new IAC motor and replaced it today. I also reset the tps before starting it. On the first startup, it started great with me not having to give it gas. We then set the IAC to 10 in park and shut it off. Then I restarted it and the problem is back. The IAC's went to around 70 and stayed there. This is with the adjustment screw all the way in. It still wants to stall at traffic lights too. Any suggestions as to what the problem is. I really need this problem sorted out. Thanks for the help.
