Identify return and feed (oil and tranny) ***PIX***
nero
The trans line... the circled one without the rubber hose (it's the top of the two lines when viewed from engine compartment), is that the feed or return line?
The circled oil cooler line... feed or return and does it go to the top of the radiator or bottom?
Trans cooler unit... should I use the bottom port as the return?
Thanks!
Oh yea.. I'm bypassing the radiator for transmission cooling. Do I have to get plugs for the radiator back or could it be left alone/open?
Looking directly at the trans, not at the lines (in case they're crossed) the top port is feed the bottom is return. The oil I'm not sure.
Thanks... do you know if I have to plug the rad holes (I won't be using the trans cooler on radiator)?
Thanks again
you can plug it if you want but you dont have to, i had mine unplugged for 2 years with no issues
Thanks!! Yours isn't a garage queen is it? Only asking 'cause it's a daily... thanks though!!! Much appreciate the input!
cooler
The one in the pic--run your supply line (oil or trans fluid) to the top port--that's the way factory does--that's the way I run mine--been going well for 10 years
