Identify this plenum...
Basically I'm trying to figure out if I should be running a power plate or not (even swapping back to a stock plenum with a plate) or if this one has similar benefits to the power plate. I haven't seen enough of these suckers up close to be able to tell exactly what it is... :confused:
If it helps any, I was looking at it from the driver's side and the top of the front bolt that attaches the plenum lines up with the bottom of the throttle body. From what I can tell that might point toward the accufab unit, the PTE looks taller. Anyone?
Too bad my engine bay doesn't! Yours is *clean* man, clean...
I guess I'm still in the wrenching phase cleaning up the previous owners boo-boos, so it's ok ;-)
Cool about the Accufab. I'm going to call about the power plate and confirm with them.
