Any way to identify a turbo harness compared to a NA harness? I have one here I was told was a turbo one but can't tell 100%. Any help would be appreciated.
Different connector lock on the computer. 86's use a metal tab lock, the 87's are a push type plastic lock. It's the easiest way to tell the difference.
The give-away is that hard plastic L shaped wiring channel. It's only used on the turbo car. Also, look for a red wastegate connector...there should be two, one for the canister and the other for the wastegate.
