Hello, I'm a real newbie at this and I've read as many threads as possible on the subject of installing, tuning, and using the FAST system.
I will soon attempt to fire up my engine and I have read here that it is better to have idle in open loop. If I do so, how do I know that when first cranking the motor, I am too rich or lean (aside from pulling the plugs each time)?
If I could crank and watch the 02 readings, make some adjustments, and crank and watch the 02 readings, wouldn't that be easier?
Also, is there a danger or damaging the 02 sensor during this phase when I'll be basically using the hit and miss method to get my engine to fire and then idle?
Does everyone normally play with the VE table first? or the cranking tables, etc?
Short list of specs
383SBC
FAST B2B WB02
TPIS Miniram 2
#36 lb injectors
MSD 6AL, SS Blaster coil
A sample .gct file would greatly be appreciated.
Thanks in advance,
Owen
Short list of specs
383SBC
FAST B2B WB02
TPIS Miniram 2
#36 lb injectors
Thanks in advance,
Owen
