Idle Issue?
pcella84GN
Pcella84GN
It seems i just cant get this car to idle smoothly.... I have done just about everything possible. and still idle like crap after a cruise. my RPMS jump from 800, 750, 850, 720, 750 and so on..Is this a known problem for these hot air cars. or am i missing something???
Mine did until I got the Turbotweak chip. Smooth as glass after that. Check around all the sealing spots like egr valve, intake gasket, throttle body gasket, exhaust, turbo, etc, etc. Spray carb cleaner at those areas and listen for a change in RPM.
Another suggestion, go to the user control panel and describe your car like most everyone else does. This will help to see what setup you're running, any parts that are questionable, etc. What year car, what injectors, chip, intake, up/down pipe, exhaust, any other mods, etc. Just a suggestion, so that more people may be able to help.
Squid
