Can't figure out why. I'm a newbie to FAST.
Fooled around with as much as I could. Closed throttle blade, opened it. Watched IAC numbers go up and down with changes. TPS is around 5% at ilde, and I have the min. idle TPS set at 7% (or at least one to two points higher than TPS at idle)
Any help would be great.
Car is idling around 1400RPMs. Yes it is hot, at 165F coolant. I guess it's in closed loop. Where do I look for that??
Scott
Scott
