Ign Key Won't Turn All The Way Back.
HighMileage
Albany,NY
This problem has gotten worse over the years.
My ign key won't turn all the way off unless I make the tilt column straight or tilt it down.
Right now my key won't come out at all because I can't get that final click back.
Sometimes fiddling with the shifter while in Park,plus tilting the column down will help turn the key back.
Is there an adjustment for this?
Thanks.
Turn the column ring counter clock wise while in park.
you can adjust the rod under the car too to avoid turning the column by hand.
Ok,thanks for the replies.
I ordered those bushings.
I just can't be going places and leaving the key in. We know what will happen.
Thanks again.
