Ign. module 84-87 plug-pin layout
fbodlovr
1/4 Mile Freak
I was trying to find a layout of all the wires that are in the 84-87 ign. module conversion plug from caspers. I have been having a problem with running extremely rich for a long time, and everything seems to be right. I have talked to a few different guys, and all of them are kind of baffled, and think the only thing it could be is something with the ignition. What I want to do is find what wire provides the power, and test it and see if its getting enough power because I know the 84-85's have resisntance in the lines. So, If someone could help me it would be GREAT!!!!
Try this link
Ignition Module Swap
1984-85 Turbo Regal C3I Ignition Module Connector Pinouts
PIN WIRE # DESCRIPTION WIRE COLOR
A 423 ECM B4 EST WHITE
B 424 ECM D5 BYPASS TAN/BLACK
C 430 ECM B5 REF. HIGH PURPLE/WHITE
D 121 TACH LEAD WHITE
E 951 ECM ALL CAM YELLOW
F 453 ECM B3 REF. LOW BLACK/RED
G 918 CRANK SENSOR B SIGNAL GREEN
H 952 CRANK SENSOR C GRND BLACK
J 916 CRANK SENSOR A 12V WHITE/RED
K 952 CAM SENSOR C GRND BLACK
L 917 CAM SENSOR B SIGNAL BLUE LT
M 916 CAM SENSOR A 12V WHITE/RED
N 439 IGNITION POWER PINK/BLACK
P 839 IGNITION POWER PINK/BLACK
