Toddmc66
Import punisher.
- Dec 26, 2012
Having a problem with the coil pack dropping two cylinders on the same coil. The drivers side coil #3 & #6 keeps dropping out while driving. It will loose spark and then a mile or two it will come back on line. Under boost or high rpms the ignition starts breaking up. Checked all connections and all are good. Before I replace the coil pack or module I was hoping to get some input. New plugs and wires are good. All other coils are firing, just the one coil is failing. I'm assuming it's the coil pack because if it was the module none of the coils would fire,,, past experiences unless you've seen different.
Any help would be appreciated.
