JDSfastGN
- Jun 16, 2001
I just installed an alky kit from Alkycontrol that I bought from a member on the board. It was all new in the packages but is not the newest setup with the ethernet style cable coming from the knob. So I get it all installed and turn the key and all the lights light up and the pump is on full blast. I checked voltage at the MAP. 5 volts at the gray wire, and 4.87 at the green. I know it should be 1.6 volts. I added a new ground to the sensor and that didn't help. I then did some reading on here and snipped the green wire that goes to the dash boost gauge. Still nothing. I verified the ground is good under the dash as well. Does anybody else have any ideas? Is it a bad controller?
