Ignition problem or ?
It would leave a code.
Do you have a noid light put on your injector should flash if your cam sensor is working . If you don't advance has them for 10 dollars
I'm not sure . They are cheap good tool to have when spin the motor over should flash if they do that's not your problem
Tired of this now,no inj pulse or spark,going for a new ecm(were can i get one)and a coilpack
Hi!
Run the car for the first time after vinter.
Run great for 10-15 minutes the i stepped a little harder on trottle a few times,did gtreat but after third time it backfires and did not responce to trottle just backfires,had to run it on idle back to the garage.
t runs fine at idle but as soon ju give it a little trottle it starts to wobble and if you continue to give it more trottle it backfires by the exhaust.
Any suggestion
did you have to jump the car to get started?
I dont have stock battery harness but i will look for that,what is it for and were does it go?
Asume its a positive one,only one thats orange?
There is a single orange wire normally located at the stock battery box area that has a black connector, it goes to the ecm. If it is damaged or unplugged the ecm will not work at all. Just check to make sure it is in good workin order.
I have 2 orange in one hose at the battery area, and they have +12v all time.
