Ignition wire colour?
AJ_08
Hello,
1987 Buick Grand National.
Does anyone know what the ignition wire colour is (12 volts power wire when cranking) ?
Are you looking for an ECM sw 12v that stays hot cranking? I use the factory one in the C437 plug the factory engine harness uses to plug into the dash harness. It is Pin F
Are you looking for an ECM sw 12v that stays hot cranking? I use the factory one in the C437 plug the factory engine harness uses to plug into the dash harness. It is Pin F View attachment 399559
No, was just looking for the ignition wire that gets 12 volts when the key is turned/cranked and sends a signal to the starter. But this is good information as well. Cheers.
I assumed this location for the "crank" wire. Same color with or without factory alarm system.
