SignUp Now!Originally posted by Bent6
I was running the MSD/DIS system on the race car until the DIS system developed a problem in BG this year. Turns out their were several DIS systems that took a dump in BG. MSD has some issues with that system. We ended up going back to the stock Buick ignition system. I have heard some folks say the stock ignition is marginal once you get into the 10's - this is bull - my car has been 7.70's on the STOCK ignition. Anyway, we are planning on going to a regular distributor system with an MSD 7AL box as it will eliminate any ignition drop outs and is supposed to be worth several more HP.
Originally posted by Mac in SD
Bruce, you'd be tickled to know that I'm running the stock ignition system. I'm also running the stock ECM (hi impedance mod) with 96 PPH injectors. MAF Trans, 3.5 MAF. This with a 9:1 CR 274 Stage II with Stage II heads, T-76 Q-trim. Works like a charm. Runs VERY strong, idles extremely well, runs cool. ...and they said it couldn't be done.
Actually passed the CA Smog Test-only sniffer (with a cat.)
Originally posted by Reggie West
Anyone try the coil on plug set up yet?
Like the LS1s use? Might be interesting.
I had it on good authority that using that set up was worth about 1000 rpms on the same motor.
Originally posted by bruce
7.70s, who'da thought.
