84 NA regal cloning to 82 TRSC.
I swapped the ECM and harness from 84 to the 82. Inside the car I plugged in the 82 ECM and the Map. What does the other black connector go to? It's been two years since I stripped the 82 and just cannot remember. I thinking heater controls, but I don't see anything. The 84 has A/C, but the 82 didn't would that matter?
Does the ignition harness run directly under the turbo on the pass side?
Where does the ECM harness run on the motor? Under the turbo on the pass side around the back and up the DS valve cover to the smog pump?
Anything under the pass side of the turbo just seems like it would cook, but that's where it seems to want to lay.
Appreciate any help, pix might even be easier.
Thanx
Thanx
