WarWagon
Caustic Cacophony
- Mar 10, 2007
I've been after this machine for a while and I finally was able to get it, This is a very old swap that has been done about 20 years ago.
Machine: 1984 Isuzu Impulse
Swap is: '79 turbo 3.8 block that has a lot of Kenne-Bell parts like a 1XB camshaft, valve locks retainers and valve springs even a KB #1 intake manifold with a Holley vac secondary 600cfm carb. Later turbo aluminum valve covers and custom ceramic coated really really long tube headers, 2.5" collectors into an H pipe that has two cat converters and a Ravin muffler with turn down by the rear axle.
Borg-Warner T50 5 speed transmission.
Narrowed 7.5" differential with stock axle tubes welded on, stock 4 lug axles.
Holley FPR and Summit electric fuel pump. Fuel system is a return style with a nice stock EFI baffled fuel tank.
Car has: A/C, power steering, cruise control, all power creature comforts stock.
This machine was in Ohio it's whole life with a quick stint in Indiana and now home in WV.
I'll have owned it for two weeks on July 7th.
This engine runs extremely well and I've had it to 7000 rpm a few times now already and it just rips. Idles like a stock camshaft around 900 rpm and lots of torque everywhere. The engine appears to only have a balancer on the crank not a damper, it's runs great as is and I plan on keeping it NA. I don't know exactly what is done to the engine, I only know what I have paper work for and can visually see and confirm. Some work is done to the heads but who knows to what extent, the block is black the heads are red. I do know this engine turns more rpm and runs better than any of my turbo engines ever did off boost.
