In need of help, Buick brothers. '87 T Ltd.
IceHockeyJedi
My plan was to keep this car and pass it to my son. However, I now have medical bills that must be attended to. Located in St. Louis, MO $4,500 OBO GEDC0463.JPG 1987 Buick Regal Turbo T Limited 102,xxx miles Title in hand
Details:
1 of 1,035 made
Rust free body
Repainted in 2009
Frame has surface rust
New power steering
New water pump
New windshield and rear glass
Rear tires have less than 200 miles
Front tires will need replacing in the near future
All oil changes done at 3,000 miles with ZDDP added
Digital dash completely refurbished by Casper's Electronics
3 inch downpipe TE-44 Precision Turbo
42.5 lb injectors Accufab fuel pressure regulator
Field fix kit from Kirban's
One year old alternator with warranty
Brand new Interstate battery with warranty
Shaved trunk lock
Alarm with keyless entry
A pillar boost gauge
Turbo Tweak chip set for 15 PSI/93 Octane
Flowmaster dual exhaust
Aluminum radiator
Comes with:
Complete vacuum brake setup
Extra rear bumper
Driver side rear view mirror
4 GN wheels with Turbo 6 center caps and lugs
Receipts to show all work that has been done
The following doesn't work:
Cruise control
A/C (doesn't blow cold)
Windshield washer motor (doesn't spray fluid)
It also needs:
A headliner
Rear bumper fillers
Weather stripping around both doors replaced
New window tint (peeling in spots)
My plan was to keep this car and pass it to my son. However, I now have medical bills that must be attended to. Located in St. Louis, MO $4,500 OBO View attachment 219209 1987 Buick Regal Turbo T Limited
Details:
1 of 1,035 made
Rust free body
Repainted in 2009
New power steering
New water pump
Shaved trunk lock
Comes with:
Extra rear bumper
Cruise control
It also needs:
A headliner
Rear bumper fillers
PM sent. Absolutely interested.
I posted an ad here instead of Craigslist because I want my car to go to a good home.
It has your typical rear main and pass. side valve cover leaks. They are minor.
The residue on the underside is from the power steering leak it had, which has since been fixed.
Is the color black , it is hard to tell from the pictures . Is the car road worthy ..?
Yes, it's black. It's certainly roadworthy. It starts right up every time and pulls well. The ride is ok. I was planning to put Bilstein's on it in the near future.
In line if others fall through.
Do you have better pics without green tint to them?
Pm sent
