NY Twin Turbo
All the good stuff.....Times 2.
- Dec 10, 2014
Does anyone bother to do this? Until recently I didn't want to bother. I also never thought there was any gains to be made. However, I had a little time one day and decided to try it. I believe I noticed a slight improvement with my idle. I also believe I could be going crazy and it could be nothing more than my imagination.
Iv'e got big injectors and maybe it helps to have the gap facing the intake valve? I don't know.
So, to make it easier, I decided to purchase indexing washers for my AR4132 plugs. Turns out, I don't like the washers because they are too loose on the plug's shank. They don't fit tight enough for the plugs to be center in the washer.
So I decided, as long as the ground strap doesn't have it's back to the intake valve, then this is good enough. No need to have it dead on. I don't have all day and 20 plugs to through away.
Any comments?
Any comments?
