It is possible with very large injectors to have the dash show the injector duty cycle as 0, but this would only be at idle. You can make adjustments to the injector opening time to help control the larger injectors at idle. These changes are not so critical at WFO so it won't effect the tune as much up there. If the duty cycle is always reading 0 then there is something wrong with the box.
