Injector cap?
Lt4-turbo
I just bought some 36# blue top injectors and one had a damaged plastic cap where the fuel sprays out. Where can I get one of these? Should I be able to get one at a local parts store?
Thanks, Jon
It should be included with a seal kit. Check with your local parts house to see if they carry a seal kit or check with your local Ford dealer. Probably if you bring your injector into a local parts house, they will have a better visual of what you need.
I was just about to give up on finding the seal kit with the cap. I had allready been to four places and they all said you might as well buy a new injector because no seal kits come with the cap. I decided to try NAPA and the cap was included. I put it on and it worked perfect. Thanks for the info. Jon
