Jan Larsson
- Nov 22, 2001
I might get some new injectors when I get started on my engine bay.
I currently have 42.5 lbs injectors and a custom chip (Jay Carter) that works very well. I'm running stock turbo, RJC power plate, 160 degree thermostat, forged pistons, polished rods, hydrulic lifters, cam 211/20/-109 (might been swapped for another one but have to look it up...). Also the valve springs been changed.
Transmission been built with heavy duty parts, shift kit and a 2500 stall converter.
I got a adj fuel pressure regulator, adjustable wastegate, THDP, no cat (test pipe) with a hooker cat back system. Walbro 307 fuel pump, valve cover vents (both sides), throttle body bypass.
Would you recommend getting new injectors, either same size or larger? Reason for replacing them would be they were installed in 1995 and have about 50k miles on them and as I'm replacing a lot of other stuff detailing the engine and also replacing all sensors etc I thought it might be a good idea to do the injectors at the same time instead of leaving them for later.
Any advice appreciated
Jan
Jan
