I need to know what size my Siemens injectors are. The only number I've found on all of them is 3102 (it's molded into the side where the harness plugs into) .
Also I need some suggestions for what spark plugs I should run with my new set-up. It's Stage I block with a all forged bottom end, TA 14 bolt SI heads (no work done on them), p/p stock intake, a comp sold roller (.623/.616 lift, 240/234 dur) cam, a PT70, and fmic.
Any help would be greatly appreciated.
Thanks,
Craig
Thanks,
Craig
