Injector swap
Do you have to remove the turbo on an 84 regal to do the injector swap? Also will 87 model injectors fit an 84? Just bought some 87 model 36lb injectors just assuming they will fit!
Yes and yes. The larger injectors will require a new chip as well. Brad
It came with a 93 octane chip for the injectors, it's all stock motor, 87 ECM, and module upgrade that's it, what kind of powergains do you think I will get by this setup
