SpeedRacerX
Bunch of parts just taken off my GN. Stock/factory parts have 94,000 miles. Nothing had an issue when it was removed. Most aftermarket parts are 1-3 years old with anywhere from 100-300 miles on them. All prices are PLUS shipping unless stated as shipped. Open to offers and package deals. Bear with me as some of the items were hard to determine a price for. Tried to price aftermarket stuff at 50% or less of new price and the stock stuff priced very low IMHO.
Pics to follow. Ask questions and let me know if you need different pictures. NOTE: With my work/travel schedule, it could take me anywhere from 3 to 10 days to get stuff shipped out, meaning, I usually ship on the weekend but will do my best to ship as soon as possible.
1. TT 60# alky chip. $60 shipped.
2. VDO oil pressure gauge and sender. $40.
3. VDO Water temp gauge. $30.
4. GNS 4 gauge holder for front of console. $55.
5. Stock heads with updated springs. $150.
6. Speedhut electrical trans temp gauge. Need the sender from Speedhut. $40.
7. Speedhut electrical fuel pressure gauge with fuel rail transducer. $85.
8. Stock pushrods. $5.
9. Stock valve covers. $50.
10. Stock flywheel. $30.
11. Stock rocker arms. $50.
12. Stock lifters. $25.
13. Stock timing set. $25.
14. Factory exhaust manifolds and crossover, welded, no holes, painted with POR15 1200 degree hi temp aluminum color paint. Will include remaining can of paint so you can paint the crossover to match. $200.
15. 60# injectors, Turbo Tweak, Siemens, 1 year old, 100 miles. $135.
16. Egr valve and cap. $25.
17. 3" to 2" silicone coupler. $5.
18. RJC racing power plate for factory plenum. $32.
19. Straight push in passenger side breather. $15.
20. Angled driver side breather. $25.
21. Braided turbo return line. $40.
22. Lower coolant hose, used, no leaks. $5.
23. Stock intake manifold. $350 FIRM. The core is worth $350.
24. Stock Throttle body and dog house plenum, plenum drilled 3 places on pass side for 1/8 NPT and two 3/8 NPT with one having a brass plug. $40.
25. Stock flat tappet cam. $25.
26. Stock power steering pump and pulley, no issues when it came off. $30.
27. Stock oil pan. $30.
28. Stock front cover. $40.
29. Clamp on, no weld, AEM O2 bung, allows you to drill hole in downpipe for O2 bung and not need to weld. $20.
30. Repro GNX body bushings pair. $15 shipped.
31. Stock tensioner pulley. $10.
32. Stock diff cover. $10.
33. A-pillar double gauge pod with hole for alky light. $16.
34. 87 GN stock ECM perfect. $100.
