Injectors.
calais1965
Hello!
I am looking 140 or 160 injectors for my setup, what do you recommend.
Where i can buy these?
Is modding ecm only way to get these fit to buick engine?
JP
injectors
Thanks!
where i can get my ecm modded?
Hello i am building my motor and i am going to use it with e85.
I have
gn1 aluminium heads
212/212 cam
je-pistons
cks crank
k1 rods
4Xbillet caps
big front mount ic
70 throttle body
kb headers
Tial wastegate
maf-translator pro
aeromotive a-1000 with 1/2" lines
Holset hx-40 super
devils own alky-kit
Bob Bailey I believe still does it, hell Cotton would know so when you score those Injectors talk to him.
I'm not sure if Eric Marshall of Turbo Tweak does it too but he sells injectors and chips so he's a one stop shop.
Injectors
Thanks for info!
Here is my new 1987 T
Thanks!
Have not tried this myself, but Racetronix is advertising an Impedance Converter Harness saying "Allows the use of low-impedance injectors on computers designed for high-impedance injectors".
Racetronix - Impedance Converter Systems
They have one listed for a 4 cylinder and two for 8 cylinder engines, you might ask about making one up for a Buick V6
Thanks!
I did emailed to racetronics, now we have to wait for answer...
Check out forcedinductions.com. I need to doublecheck fit but their 160lb. Bosch set of 8 is only $499. You could sell two and...
Jim
Not sure what your budget looks like, but if you want the best:
http://billetatomizerinjectors.com/
He can do high impedence 160s also, so no drivers needed (Don't have to mod the ECU). Yes, they are expensive, but you will get your money's worth :)
