Injectors
turboman38
It costs money to go fast
Is there any way to test injectors while they are on the car? I have a miss pretty much the entire way thru the RPM range when moving at a steady speed. I replaced the module,coil pack, MAF, crank sensor etc. I'm running MSD 50s. If they can't be tested on the car I wanted to swap out a known good set of injectors. Since the car misses at idol I figured I could put stock injectors in without changing chips and if the miss goes away then I know it was one of the injectors.
I have no problem buying another set of injectors but 009s will not be enough after I get my heads and intercooler mods on and 55s need the ECM mod done.
Anybody have any ideas?
Very carefully inspect every inch of each injector wire on the harness. Look for pinched/burned wires.
