innovative boost controller map sensor
tvgn86
anyone have an available map for an innovative msbc 1 boost controller or know of a suitable replacement for one? I have a working control box and no map . Thanks
what model
have you tried contacting rick at exile , they made the msbc-1 when they were innovate turbo , now they are labeled as exile deeds ET-01
if its older version turbo 7 or 12g its a 5bar sensor (60psi), check the sensor supply voltage i beleive its 5 volts ,then do a search for one
the reason for the reflash is the 12h and et-01 were upgraded to go to 80psi , he only stocks the latest 80psi sensor
Thanks for the information . I will research a five bar map . Any other info is appreciated .
