You will need some tye of pressure sensor capable of reading upto and or more than you want to read.
It needs to be a 5 volt sensor and you will most likely need to mount it to a
peice of steel line to keep it away from the direct ex heat.
Then you will need to calibrate this sensor in the XFI once this is all done
Hope this helps
