Installation instructions for Reds’ Volt Booster
1KWIKSIX
Looking for installation instructions for Red Armstrong’s Quad Air Volt Booster
remove plug from side of alternator , cut brown wire about 1.5" from plug and install spade terminal to harness side of wire
(keep the plug and install a mating connector incase you need to remove booster)
connect vbooster T hose to boost source
connect brown wire to wire from vbooster ,
plug vbooster into alternator
verify charging when running ,
go boosting and you should notice headlights go bright when you boost (typically comes in at 10-12psi) or you could connect an external air source to test boosted voltage
Thanks Pacecarta,
I’m looking for the hard copy of Reds’ install instructions , I’ve misplaced mine
Here’s what I’m looking for
I might have them, I have an extra Red's VB on the shelf at home. I'll check tonight.
Send me your e mail. I have them scanned to a PDF pretty clearly.
If anyone else ever needs them, let me know.
