Vplus volt booster w/ progressive alchy controller
ANDYS87
I will be installing Julio's alchy kitnon my car this summer. I currently have a caspers volt booster. Will the extra voltage screw up the progressive control?
If you search that info here you will get mixed opinion/results,, i have both and without any change to my tune the v/booster fattened my Wband # from 10.7 to 10.5 on a full pull, which i was ok with as i keep in near 30Lbs. And that is all i saw. I'm sure if your racing and chasing an ET slip,,it could be an issue and need to adj the tune.
It will richen the afr by sending more volts to the pump.
