Installing a TH350/400
Th350 trans w/ proper speedo gears,converter,dipstick/filler tube,kickdown cable,and a vaccuum line to the modulator with a check valve to properly "read" engine torque load in boost..Trans lines,mount,driveshaft,x member,shift linkage,all will work.Good swap for a mild racer as the gear ratio is more favorable than the 2004r.
sent email to you about same issue
Chris,
Sent you an email asking some questions.
Thanks!
Chris
help
I need that check valve, where do you get one at!!
I have a TH-350 in my car that I traded a forum member on here, it was a fresh trans with shift kit. I think the guy who put the trans in has the wrong stick cause it will go in reverse no problem but have to press gas alittle to get drive. Shows full but that problem normally means its a quart or two low. The kickdown cable is just plugged off don't think the stub is hooked to the little wire inside the trans. But it want manual shift at all is it the kick down cable? Even with the fuild that close it should atleast shift one time. Have reset the shifter in the car many times form setting it in park, neutral or low. I have the kickdown cable for the 200r4.
