Installing new body bushings from Kirbans
PaulRV6
For those of you that installed these bushings, I am reusing the stock bolts but what about using the thick stock washers with the new bushings? Do the bushings have a built in washer or are the thick stock ones still required under the head of the bolt?
paul
i had to use stock bolts
kirban sent wrong ones that where bigger.
also, get new washers as the stock could be ( for sure) rotten.
i got my extra bushings at a truck parta store for 2.50 each.
I used the new washers that came with the kit. It seemed to work fine.
Now that I think about it I believe the lower bushings have the washers built in. I believe that is what I used. It's been a while.
