Int(Scanmaster) is bouncing is this normal
  • Thread starter Thread starter AsphaltAnihil8r
  • Start date Start date
A
AsphaltAnihil8r
Guest
This morning I was watching the scanmaster while on INT the number were bouncing 125,to 135 to 126 to 134..
I thought that they would go up in sequence like 125 to 126 to 127 to 128
Do I have a new found problem..
That's fine long as it's not pegging 150+ or 90. Watch the BLM's and see if they stay pretty steady for the most part. That's the long term fueling. INT is short term hense why more active than most scantools can pickup. The BLM's move more slowly like you stated but can change in larger number differences as the BLM cells change according to LV8. There are 15 BLM cells that map your fueling. Steady throttle the BLM's will move more slowly.
O2's change very rapid, INT less rapid, and BLM slower yet. That is of course if not WOT.
Thanks Chad!!:)
