intake help
T/racerX
I'm putting new heads on my hot air,i bought a new intake manfold gaskets felpro and a valley pan gasket. my question is dose the valley pan go on top heads then felpro gaskets and intake manfold on top of it all ? this is a real prolem for me ..Also dose any know what 84 t-type with new motor,forge piston,proted heads kenny bell cam vales,vales spring,new turbo and rebilt transand 61,000 miles on it????
i need some feed back dose any one how to put the valley pan gasket on how it goes??????????????????????????
Valley pan Install
I`ve always used Blue RTV on both sides of the valley pan (on the openings for the ports and water openings) .Be sure to use sparingly here,you dont want it to squish out into the ports.Also use this on the end flanges,front and rear,use a thicker bead here so that it squishes out a little. Let it sit overnite to cure,or as long as possible.This method has always worked for me----Good luck
