Thanks for the reply's. I'm guessing on forced induction intakes being smooth is a benefit as well? Is it a good idea to smooth out the runners and the upper intake? And as for the EGR tower, I suppose it should jus be cut off and then welded at the bottom? I see DDrifter has welded the port to the heads shut - any risk in warping it with too much heat?
