AC Blower Relay Digital Climate Control
samsquanch
I searched all over and can't find an answer. Is there a blower relay on cars with digital climate control? If so where is it supposed to be?
My blower stuck on full after a long drive. Even with key off. I looked all around for a relay and can't find one. Is it possible it's down by the antennae motor? There is a connector that sends power to the blower that routes under the housing but can't find a relay.
no fan relay
digital ac c68 uses a fan control module installed where the fan resistor would be on c60 manual ac
last poster that said his fan motor was stuck on with key off turned out it was his power antenna motor running which wont stop if the cord inside the anntea breaks , in that case the power antennae needs to be unplugged which the plug is between fender and ac case
heres the c68
diagram
