intake vacuum Tee
xxninja
hey guys i was wondering if you could help me out
Ya know that vacuum tee on the back of our intakes, the one that goes to the regulator and the map sensor.
Well mine mysteriously vanished and i have no idea of the 3 sizes.
Do any of you know the sizes of all 3 sides? Maybe even a place where i could get one?
i'd greatly appreciate it
thanx alot
~brian
Any auto parts store should have that plastic t vac hose connector, their pretty common. I'm not at home right now, so I can't measure mine. I would just remove all 3 hoses and take them to the parts store with you so you can be certain on the sizes. And while your there, buy enough of that hose that you can replace all three when you put the connector back in. You can never have a good enough excuse to not replace rubber vacuum hose. It's cheap (and unfortunetly usually cheaply made), And with that turbo right up there next to all of those rubber hose lines (and no heat shield to boot). It's failure waiting to happen. (but you probably knew all that). And you know about wire ties at all the hose connections too, right?
