Intall of spray nozzle on razors kit?
3.8vsix
Hi, I have started installing the alky kit form razor, and got to the spray nozzle. I do not like how it fit. I could only get the rubber washer on the inside, and could not get the one on the outside to fit. So I just used the one on the inside. Is this going to be OK? I thighten it as tight as I dared but the nozzle does not seem tight. I check to make sure it was not bottomed out on anything. I have a rjc mega cooler with the 3" pipe. Thanks for any help!:)
one washer is fine. you will be able to move the nozzle with some force. unless its really loose i wouldnt worry about it.
HTH
