Unknown plug connectors - please help identify
AJ_08
Hello,
Can anyone tell me what these plugs connect to? One is a three pin and the other is a 4 pin.
Side question: my wipers work fine but the washer fluid won't spray out, I hear the relay click though. No clogs in the lines. Could it be a bad pump? I feel no suction of the rubber line to the washer reservoir when pushed on the stock.
The 4 pin should be for the power master brakes. I’m assuming you don’t have the PM anymore.
That makes sense - you're right, i have the hydroboost conversion.
The connectors are for the powermaster brake unit .. 4 pin to motor , 3pin to brake pressure switch. Solved. Thanks!
