fullahotair
- Feb 26, 2002
Hi folks,
I have been looking at the 3" downpipes vs the 2.5 downpipes and see that 3" generally have integral wastegates.
Question 1. Do all 3" dp have to have an integral wastegate.
Question 2. What exactly do you have to do to use a downpipe with an integral wastegate or do you just bolt right up to where the stocker used to be and you are good to go??
Finally. Questin 3. I measured the outer diameter of the exhaust portion of my turbo and it was 2.75" i believe. Does a 3" piece neck down to that size? Basically what does the 3" dp seal to on the turbo if the outlet is smaller than 3"?
Thanks for you time,
Nathyn
Nathyn
