Intercooler, downpipe, Cat, IC Fan..
BoostedBug
Contents Under Pressure
Make me an offer!
Stock location Intercooler that has had some port work done to the inlet and outlets. Comes with air scoop also in good shape. I will also trade for an airbag setup for the rear of my car
http://i17.photobucket.com/albums/b9...k003Medium.jpg
http://i17.photobucket.com/albums/b9...k005Medium.jpg
http://i17.photobucket.com/albums/b9...k004Medium.jpg
2 1/2" s.s. down pipe and a cat. This car hs not been long passing emission testing in N.C. so everything should be good This down pipe is designed to bolt to your stock turbo bell. I have one of those also if you need it that I can throw in with it.
http://i17.photobucket.com/albums/b9...k001Medium.jpg
Intercooler fan and mounting bracket. Fan has some chips on it but you can see these in the pictures. Also an up pipe from the IC to the throttle body. Use this one to drill into for your alky setup and save your stocker.
http://i17.photobucket.com/albums/b9...k006Medium.jpg
http://i17.photobucket.com/albums/b9...k007Medium.jpg
