- May 28, 2001
May/may not be valid info.....
http://howertonengineering.com/tech-info/calculating-jetting/
SignUp Now!you're right, interesting.....perhaps Razor will chime in..............![]()
What keeps the nozzle from clogging is running a filter pre nozzle.In my "never ending quest" to re-invent the wheel, I was surfing the net for some ideas for a direct port alky nozzle.
I was wondering if one could take the newer design Aquamist nozzles, put 1 in each port, and tune from there.
The AM nozzles have a filter and a check valve in each nozzle, preventing siphoning, and helping to prevent clogging. The check is set to prevent lag when the alky is triggered. [Or, so I understand, anyway.]
My LS project may just be a candidate for this foolishness!
Julio, your system hooked to the AM nozzle set????
Quite indeed... just need to be careful.. Its great to take an initiative to write something and make an article with the hopes it helps someone.."There is a lot of wrong in that article."
I didn't say it was correct, only "interesting".....![]()
